Discussion topic: Sky broqdband not working
This message was authored by: Richard306
Richard Rismay
Re: Sky broqdband not working
Not a lot to go on there @Richard306
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
