Discussion topic: Sky broadband speed and package.
Message posted on 11 Apr 2024 12:03 PM
Hi there. I'd like to make some changes to my broadband package. Firstly, my package includes a landline and associated charge. I want to cancel this as I no longer use my landline - it is a waste of money. Secondly, I'd like to request a new router and a boost to my broadband speed. The router is very old and my broadband speed often lags. I look forward to hearing from you. Thanks.
Message posted on 11 Apr 2024 12:10 PM
Re: Sky broadband speed and package.
You are not speaking to Sky this is a public forum.
A telephone line or fibre cable is required to deliver your broadband so you'll always have one however the charge is included in your total monthly cost so if you see a separate charge for landline its likely you have a calls package that you can remove.
As for a new router, which router do you currently have? You are not automatically entitled to a new router. The Sky Q hub (ER115) is the default router for Sky customers who do not have boost or SOGEA. If you have broadband boost then you should have the Sky Broadband Hub (SR203) & if you have Sky Max then you get the Sky Max hub.
