26 Aug 2022 08:03 AM
I'm trying to disable the bb shield but the save settings option does not highlight. Can someone pleas help me to disable the bb shield. Thanks.
26 Aug 2022 08:06 AM
Posted by a Superuser, not a Sky employee. Find out more@Katb2 check you are using the Sky id linked to the account as only the main account holder can change the settings. If you are give Sky a call as there could be an issue with your account set up.
26 Aug 2022 08:10 AM
Thanks, I'm just waiting for the lines to open. I am the account holder. It's very frustrating. I've been trying to sort it out myself but it just won't let me save the Disable option.
26 Aug 2022 08:57 AM
I've managed to sort it out now thanks chrissie. I had to disable the shield via the 'customise preferences' option. I was then able to save the changes.
