Discussion topic: Sky broadband internet not working
Message posted on 02 Aug 2025 06:58 PM
hi - unable to reach customer service as today from 4pm internet is not working could not connect WiFi how to reach direct contact or technical support
Message posted on 02 Aug 2025 07:19 PM
Re: Sky broadband internet not working
@Vigneshsiva
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Message posted on 02 Aug 2025 07:30 PM
@Vigneshsiva To do as you have posted the calling sky is the only way!
Message posted on 02 Aug 2025 07:39 PM
@Vigneshsiva
These are the current methods for contacting Sky…
▪️online help via
https://www.sky.com/help
▪️ Sky Assistant is also available at the top of sky.com/help for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
▪️You can also get in touch with Sky via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
▪️call Sky by dialling 150 (free) from either a Sky Talk landline or a Sky mobile. Calls to Sky will start automated which may try to send you here to the forum or offer you the online help route. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is not likely to work.
Message posted on 02 Aug 2025 07:44 PM
Thank you... I have contacted sky. They said they would assign an engineer visit
