Discussion topic: Sky broadband has no Internet
This message was authored by mercedes92 This message was authored by: mercedes92
My Sky Broadband box has three green lights and devices apart from Sky Tv Boxes all work.  i have tried unplugging ethernet cable from both ends and unplugging all sky devices and plugging them back in after a period of time but still no look. Can anyone help?
Re: Sky broadband has no Internet
@mercedes92Are these problems still ongoing for you this morning?
This message was authored by Sky-2022 This message was authored by: Sky-2022
Hi, @mercedes92.
Can you run the Broadband Test, this can be done either via the MySky App on mobile data or use this link. If it shows a fault you should be able to book an engineer via the app. Also, could you post your Router stats and a 24hr system log, also holding down the reset button back of the router for 20 seconds will reset it back to factory defaults: note this will reset any changes done to the router? This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
I may also add, that reduced WIFI speeds are extremely common. As the location of the Broadband Hub, the structure of the property/location using the WIFI, how many devices are connected and external interference from neighbours' WIFI on the same channel, usually pressing the reset button on the back can solve this issue as it will auto find the best channel to connect to. Moreover, the practical solution would be using ethernet cables preferably CAT5e or above for most activities that can be supported for. And adding various external WIFI boosters may not solve the issue but cause more interference. Sky does not guarantee wifi speeds unless you buy their top-up Boost package and even then it is only minimal speeds but they normally will give those customers a booster if asked.
Otherwise, to discuss your issue further it would be best to call sky on 150 from your landline or
zero three three three seven five nine one zero one eight from any other phone.
Sky Q UHD 1TB (on ethernet) & Sky Superfast - SR203 router (59mbps downstream, 16mbps upstream - average)
If my reply is correct/up-to-standard mark it as answered.
If I get it incorrect, educate me - I am open to learning from others as we are one community.
If I say something you find informative and helpful give me a thumbs up.
I am trying to level my way through progressively 🙂
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@mercedes92
Perhaps perform a network reset on the Sky TV box, are you using Sky Q or Sky HD+?
"Sometimes, the only choices you have are bad ones, but you still have to choose"
