Discussion topic: Sky broadband down in Buckinghamshire
Message posted on 30 May 2025 03:28 AM
No broadband and we're in the middle of Alevels preparation as. Troubleshooting on Sky app says all good but not true. This happened earlier in the month and they gVw us free movies we didn't like as compensation. How about refunding subscription fees for lack of service?
Message posted on 30 May 2025 05:19 AM - last edited: 30 May 2025 05:20 AM
Re: Sky broadband down in Buckinghamshire
@Mee25
The Sky Community is a customer led discussion forum where Sky customers are available to help other customers. You are NOT contacting Sky Customer Services by posting here.
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. If it hasn't come back on by 0700 use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
If it's a longer term issue, in the UK the service level agreement between ISP’s and Openreach for fixing a fault is 2 WORKING DAYS.
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From the Ofcom website:~
So if your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day). There is no equivalent scheme in place for customers in the Republic of Ireland.
Message posted on 30 May 2025 08:12 AM
@Mee25 Lack of service, there is no 100% absolute for a domestic Broadband Wi-Fi, you need it all the time then have a backup plan, with a backup plan to it also...
