Discussion topic: Sky box unable to connect to router
Message posted on 31 Dec 2023 08:38 PM
Why is it but every few months my sky q box disconnects from the internet i currently have net as im writing this discussion so it's nothing to do with the internet as such.
I know when it's not connected when the home screen dosent show anyh content anxd im also unable to use any of my streaming apps.
I never had this problem at my old address and it seems to be more prominet since i've upgraded my internet.
I can solve the problem by either turning the box off and doing a reboot but it should just connect when i try and connect it from just the sky box itself.
Message posted on 01 Jan 2024 07:52 AM
Re: Sky box unable to connect to router
@Mr+rightxx the issue will almost certainly be a marginal wifi signal. Give Sky a call after the holiday as it pointless calling today and report the issue with your Q box they will either send you a booster or arrange for an engineer to come out . If they send a booster plug it in halfway between where your Sky hub is and the Q box as the unit requires a good wifi signal to operate. Also ensure all wifi units are not under other kit or in a cupboard.
Message posted on 01 Jan 2024 11:02 AM
@Chrisee thanks for your reply the house we are at is a new build 2 years old and i cant understand why bt have put all the connections under the cupboard stairs 🤔 so i always thought that this would be the problem.
But it's just strange why it cant reconnect it's fine once i restart the box. This will then run fine for a few months and then we will be back to square one again.
Message posted on 01 Jan 2024 11:09 AM
If you are in a new build, perhaps the builder has wired data points in all of your rooms
and back to that central cupboard, these are RJ45 connection sockets that you would see in a room
and multiple sockets in the cupboard.
If you are fortunate to have this, then a pair or Cat5E patch cables will allow you to move the router
to a far better location.
Have a look and see if this applies for you.
