Discussion topic: Sky booster
This message was authored by CarinaJ This message was authored by: CarinaJ
Sky booster
Since we got a sky glass tv our booster doesn't want to connect. I think it was connected to the Sky Q box before. I've tried to reconnect it and also to reset it, but nothing is working. Am I doing something wrong?
This message was authored by McMucker This message was authored by: McMucker
Re: Sky booster
If it's a sky q booster I would suggest you might run into problems, you'd be best off with standard mesh network without using sky technology.
Re: Sky booster
@CarinaJ the booster needs to be within range of your Sky hub as Glass does not work as a hot spot unlike Sky Q so you may have to move it closer. Boosters need to be placed halway between the hub and where you need the signal.
This is the info to set up a booster https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
