Discussion topic: Sky booster pod poor signal
This message was authored by: Sam+Smith
Message posted on 12 Nov 2025 09:18 AM
Sky booster pod is getting a poor signal. I only have one booster pod and have moved it around to try to get a better signal but if I move it closer to the sky max hub I can't get WiFi in my whole house.
Find out more
Message posted on 12 Nov 2025 10:38 AM
Re: Sky booster pod poor signal
Hi @Sam+Smith
Ideally your Sky hub needs to be placed centrally in your home, then you use booster pods to extend coverage where its needed. If one pod isnt doing the job then you likely need a second as placing a pod too far from the router will result in a poor experience.
I am NOT a Sky Employee
