Discussion topic: Sky booster linked via Ethernet not working
This message was authored by: Cardiff2510
Sky booster is indicating that the  power, connection and Wi-Fi are working but there is no Wi-Fi available.mthe boosternis in my shed and connected with an Ethernet cable. Wi-Fi in the house is working. Has worked fine for c3 years until today....
Re: Sky booster linked via Ethernet not working
@Cardiff2510 if a simple reset doesn't sought the issue it sounds like the booster has failed if Sky provided it try calling them as they should replacecit but current boosters lack the Ethernet port so you maybhave to find a used one on line.
To reset the booster press in the reset pin until the power led flashes.
Avatar for Cardiff2510
Great, thanks. I reset 4 times and on the 4th it seemed to work?!
