Discussion topic: Sky booster & routers
This message was authored by: Gjp82
Weve just moved in to a new property, broadband being connected next week and our old router is in a box waiting to be moved to new property - also next week
i do have however a sky booster box (white, three lights on the front, all green - power, connected, wifi) so the property does look like it has wifi left over from previous tennent.
am i correct in thinking i cant use a booster as a router?
previous tennents provider was vodafone so not sure if that comes in to the equation, tried my passwords from previous property, no joy, i was thinking of buing another router to see of that worked?
if not, ill just have to wait but would really apprecite wififor work over the next 7 days
cheers.
Re: Sky booster & routers
No, Sky boosters are not routers and don't have the required functionality to accept a WAN connection or provision a network with a public IP, address translation, DHCP or DNS resolution.
Avatar for Gjp82
Hi. Thanks for this, I thought as much.
if I buy a 2nd hand router that's not been used, would it work?
Avatar for Gjp82
@Gjp82
If your Sky broadband isn't being provisioned until next week, acquiring your own router now doesn't help at all.
