Discussion topic: Sky booster also the power cord usb c has broken
Message posted on 06 Apr 2025 06:06 AM
Message posted on 06 Apr 2025 07:16 AM
Re: Sky booster also the power cord usb c has broken
@mr+rs+bains you need to report the power cable issue to Sky but in practice tou can power the white Sky Max hub using any USB C charger you msy have lying around
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi..
