Discussion topic: Sky Wifi Max Hub - ticking
This message was authored by: bazzabear
My new Wifi Max Hub makes a ticking noise every few seconds. I strongly suspect it is for the same reason as discussed in this conversation about the older Broadband hub:
https://helpforum.sky.com/t5/Broadband/Ticking-noise-from-sky-hub/td-p/3794519
The problem is that this hub seems to have all the settings rather locked down. To change anything, you have to access via the MySky app. And I cannot find an optiona vailable there to change the router mode to WANoE only.
Has anyone else found this issue, and found a solution?
