Discussion topic: Sky Wifi Max Hub and dual WAN
This message was authored by: shylas
I have the Sky Wifi Max Hub connected to my DSL FTC broadband. This is the best avaialable in my property. No FTP avaialable to date. The max speed my FTC broadband supports is 70 MBps.
I see that one of the network ports on the Max Hub is marked WAN. Does this hub support Dual WAN?
I have a 5G router and I would like to connect this to the WAN port for load balancing, better 5G download speeds and failover.
I have looged in to the router set up but there is no option to configure the WAN port as far as I can see.
Could someone kindly advise on this please.
Thabk you.
Re: Sky Wifi Max Hub and dual WAN
@shylas No dual wan feature on the sky Hub, one or the other, DSL or the Wan port one at a time!
