Discussion topic: Sky Wifi Max - Advanced Security feature - Suspicious Site Visit info
Message posted on 16 Jun 2025 11:19 AM
I recently upgraded to Wifi Max and was checing out the Advanced Security to see which suspicous sites/threatrs have been blocked.
When I open each device, all it seems to show it is the IP address of the site.
Naturally, I have the ability to allow access, but unless I know what and why it is blocked I dont know if I should allow access.
Is it normal to only show the IP address? pretty pointless if it is and I have no idea what it realtes to
Thanks all
Message posted on 16 Jun 2025 12:00 PM
Re: Sky Wifi Max - Advanced Security feature - Suspicious Site Visit info
@themanc55 But it gives you the ability to go look safer to why and if you wish to continue!
Message posted on 16 Jun 2025 12:20 PM
I only have the option to allow access, as without knowing the actual website it relates to I have no idea if it's genuinely something to keep blocked.
So I need to know if I am missing something obvious as to know what the IP address is for and which website
Message posted on 16 Jun 2025 12:24 PM
