Discussion topic: Sky WiFi name is not appearing even though it is on
This message was authored by: Sadie36
Message posted on 24 Sep 2024 08:55 AM
I've had Sky broadband a few weeks now but I've woken up this morning to see that none of my devices are connected even though everything is on. Trying to connect and I can't because the sky WiFi name is not appearing when WiFi is on
Find out more
Message posted on 24 Sep 2024 09:06 AM
Re: Sky WiFi name is not appearing even though it is on
There's a known current issue with the white Max Hub: a workaround is to factory reset the hub by holding down the WPS button for 30 seconds. Once this is complete, any previous changes you've made should be downloaded again from 'the cloud'.
