Discussion topic: Sky WiFi max hub with Sky Q
This message was authored by: Wez1983
I want a WiFi max hub but sky won't let me have one due to having sky Q and 3 mini boxes.
can anyone recommend a router that I could use that will work with my setup, also one that I could control from an app?
many thanks
Re: Sky WiFi max hub with Sky Q
@Wez1983
Are you on part fibre fttc or full fibre fttp
Recent posts suggest that Sky may have removed that account limitation (or are in the process of doing so)
Avatar for Wez1983
@cookiemonsteruk  as far as I'm aware full fibre
@Wez1983
Per @TimmyBGood post hopefully sky may be working on a solution to running more than 1 sky q mini with a sky max hub . This would be the ideal solution.
This message was authored by: mormegil
The q mini limitation has been lifted from the max hub ordering process
