Discussion topic: Sky WiFi max doesn't seem to allow you to change WiFi channel
This message was authored by: Skystreamuser
Message posted on 08 Sep 2024 09:28 PM
Is this for real the sky router admin pages are totally restricted and mysky app so limited ,I cwnt see a way to change even a basic channel on my WiFi signal for 2.4 or 5 can anyone assist Thanks
This message was authored by: JPR007
Message posted on 08 Sep 2024 09:46 PM - last edited: 08 Sep 2024 09:46 PM
Re: Sky WiFi max doesn't seem to allow you to change WiFi channel
@Skystreamuser Yes it is for real. Routers that use the upper 5Ghz channels (52 and upwards) have to use DFS or Dynamic Frequency Selection, in order to avoid interference with Radar.
All Modern routers routinely switch channels all day and night as they scan for the least busy channels, the days of selecting one fixed channel and being done with it are a thing of history.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
