Discussion topic: Sky WiFi max booster not working
This message was authored by: Adam2505
Hi. I have a sky wifi max router but it doesn't appear to be working very well. When I am in my lounge which is furthest away from the main router I often have issues connecting to my Sonos properly to play music and if working from that room I often have audio issues when on video calls. I'm not sure my booster is doing the job it should be so would appreciate some help or someone to come and look at it
Re: Sky WiFi max booster not working
@Adam2505 Where did you place the booster, if it is too far away from the sky Max hub then it will not be working efficiently. Have you tried different positions for the POD!
