Discussion topic: Sky WiFi Max vs Sky Broadband Hub
This message was authored by wonderwho101 This message was authored by: wonderwho101
On the highest Sky Broadband Gigafast paired with Broadband Hub I had 70mb/s whilst downloading games etc,
Without booster and using WiFi adapter I had the same,
Now the same set up with the Sky WiFi Max & with ethernet I get 100mbs but im stuck to 10mb/s on WiFi adapter/Booster
I also cannot split 2.4 & 5 channels for whatever reason
Cannot log into the defualt gateway as its all done through the app
How is this box better other than using an ethernet cable?
Re: Sky WiFi Max vs Sky Broadband Hub
@wonderwho101
It should be higher than that. Have you tried checking the speed when the pod is unplugged?
I am NOT a Sky Employee
