Discussion topic: Sky WiFi Max doesn't reach any further than old router
This message was authored by: DrGordon
Message posted on 24 Jan 2025 04:02 PM
I upgraded to Sky WiFi Max to ensure we get WiFi in all rooms, but the signal is weak or non existent in several rooms. I have done all the usual steps like ensuring the router is high up, away from other electronics etc. The WiFi coverage is no better than with the previous router, but costs more.
Find out more
Message posted on 24 Jan 2025 04:45 PM
Re: Sky WiFi Max doesn't reach any further than old router
@DrGordon the range is roughly the same but potential speeds are higher but in you bought Sky's WiFi Max bundle they should supply up to 3 pods as explained here https://www.sky.com/help/articles/sky-wifi-max
