19
This discussion topic has been answered Discussion topic: Sky WiFi Max and Sky Q issues
This message was authored by: GBSPEED
Re: Sky WiFi Max and Sky Q issues
On the first problem - have you tried updating the software on the skyQ box - I had wifi connection drop outs on my 2TB main Q box, after the Q software update - much more stable.
If you are using mini Q boxes - then the new SkyQ Router does not have a mesh capability for Q so you may need a white Q booster to get the mesh signal from the main Q box to any Qmini boxes
This message was authored by: hammerjeff
@GBSPEED  thanks for replying,no mini boxes and we are on Q270 I thought that was the current version
This message was authored by: tanddy
So I'm in exactly the same position.
I'm having issues wifi wifi calling which drops when moving around the house.
My Sky 'booster' is connected to:
2.4ghz = SSID matching the main network
5ghz = Different SSID
Do the mini boxes connect to the booster for network services  or the booster?
Wondering if switching off the 2.4 on the booster may remove the c wifi calling issue??  If prefer my phone to connect to the wifi puck rather than the booster.
Any advice?
This message was authored by: Blkmomma71
Second box not connecting with main box
@Blkmomma71 if your Sky Q mini is not connecting to the Q main box give Sky a call as thry should eithercsend out a Q booster or arrangecan engineer to visit.
Answered - Go to Answer
