80
Discussion topic: Sky WiFi Max Hub (white): No WiFi but wired connection is ok
This message was authored by Donna125 This message was authored by: Donna125
Re: No WiFi but wired connection is ok
No bad weather in Scotland just now so not connected to bad weather. After testing my broadband and WiFi connections continuously and it saying everything looked fine I tried to press wps button to see if it made a difference. Even that's not working! So just got so annoyed I connected my old sky q router and bingo everything is back to normal. Can find on all my devices WiFi lists and all connecting and working...I think the problem definitely lies in the router but tests are not picking up anything wrong
SZ1
This message was authored by SZ1 This message was authored by: SZ1
Maybe try press WPS button for 30 seconds to factory reset the router? It worked for me finally..
don't think this issue is related to weather as well.
surprised to see many people are facing the same issue at the same time..
This message was authored by NotToby This message was authored by: NotToby
+1 on the WPS button 30 sec press. It worked for me. The connection still comes and goes but I suppose it's their side of problem.
This message was authored by Nick5077 This message was authored by: Nick5077
It's happened to me as well. I cant see the router on any devices. My sky max hub was only installed yesterday and all was working fine when we went to bed, nothing when I got up. All the lights on router and ONT are fine. Tried switching off and on made no difference
Ok, tried resetting by pressing WPS button for 30 secs and that seems to have worked for me - all connected again.
This message was authored by Jamzy44 This message was authored by: Jamzy44
Same problem here. Did was reset and can now see router b...
Same problem here. Did was reset and can now see router but keeps dropping in and out. Only installed router a couple of weeks ago and new to fibre.
This message was authored by PJS37 This message was authored by: PJS37
Thank you for posting!  I was having the same issue and the WPS worked for me.  Had to try it twice.  The second time, I got the flash of green before my router (max hub) restarted.  I didn't hold it down long enough the first time...sharing that in case anyone else isn't holding the WPS long enough.
This message was authored by Doktor46 This message was authored by: Doktor46
Had the same issue this morning. I tried the WPS button and it seems to have worked, mostly. I can now see the router on my devices but the TV signal still seems to be cutting out periodically.
This message was authored by KevNewMedia This message was authored by: KevNewMedia Answer
Posted by a Sky employee
Morning Everyone
Thank you for bringing this problem to our attention and thank you @Chrisee for tagging me.
I've escalated this problem to our support teams and as soon as I hear back, I'll let you all know.
I'm marking this post as an answer, so that everyone has the most up-to-date information. This doesn't mean that it's been fixed.
As confirmed by @SZ1 a current workaround is to factory reset the hub by holding down the WPS button for 30 seconds. Once this is complete, any previous changes you've made, will be downloaded again from the cloud.
Kev
Community Manager
This message was authored by Dipti13 This message was authored by: Dipti13
Dipti Patel
WiFi not working
This message was authored by Pazy This message was authored by: Pazy
WiFi not visible
Morning
my WiFi is on but not visible to my devices.
please advise?
Paz
Re: WiFi not visible
@Pazy if you read some other tgreads you will see yiu need to rest your hub the method for doing so is on the white hub press and hold in the wps button for up to 30nseconds until the led on the frontvdtarts flashing green rapidlybthen release. Once restarted the hub should be back to notmal.
This message was authored by DJL94 This message was authored by: DJL94
No WiFi
WiFi down. Switched on and off including the FTTP box. No signal showing up on phone or laptop. Unable to work until fixed.
This message was authored by Samuel-James This message was authored by: Samuel-James
WiFi Down
Woken this morning to no WiFi connection - wall mounted device appears to be operational (3 green lights) however the WiFi is no discoverable by any device in the house. Checks via the 'my sky' app say there is a problem, but seems unable to diagnose and fix appropriately.
Any solutions to this are much appreciated.
This message was authored by Camandmac24 This message was authored by: Camandmac24
WiFi issue
Tested our connection on sky.com says there is no issues and all working but devices cannot find the wifi and can't connect
router has been turned on and off multiple times and now has a permanent red light
