7
This discussion topic has been answered Discussion topic: Sky SR203 fibre broadband router making a ticking noise
This message was authored by: BeSKyID
Hi
As many others seem to have mentioned, the router is making a ticking noise like a clock.
Can you help stop it? The posts here don't offer a suggestion, just an invite to a private chat about it.
Thanks.
Avatar for BeSKyID
Level 2 icon
This message was authored by: BeSKyID Answer
Re: Sky SR203 fibre broadband router making a ticking noise
@BeSKyID given there many millions of these boxes in use a very small % do seem to have an issue causing a noise. Standard practice is to switch out affected units which come back to Sky to be refurbished. Simply call Sky to arrange this
Avatar for BeSKyID
Level 2 icon
Hi - thanks for that. Is there anywhere that details the standard practice?
@BeSKyID Are you connected to a Full Fibre FTTP with the SR203 Router?
Avatar for BeSKyID
Level 2 icon
Yes, so I used archive.org to find the deleted thread that suggests setting the WAN from Auto to Ethernet, which seems to have fixed the issue.
I was hoping to find details on the "standard practice" though, as I am sure you have had the experience of calling up somewhere and they have no idea what you are on about.
Thanks, seems sorted now though.
Avatar for BeSKyID
Level 2 icon
No idea why it would get deleted, but in case anyone else needs to fix it:
https://web.archive.org/web/20240724152513/https://helpforum.sky.com/t5/Broadband/Ticking-noise-from...
@BeSKyID Picture change.
Set to stop DSL Relay clickingSet to stop DSL Relay clicking
This message was authored by: Spikezster
Perfect i couldn't get the archive website to load properly but this worked fine
