Discussion topic: Sky Q will not connect to the wifi
This message was authored by: Davidburden
The sky Q box keeps losing the connection to the sky router. I have done everything the box says, reset the WiFi, turned it off at the mains etc etc. it connects for a moment then loses the connection
This message was authored by: Me134
Re: Sky Q will not connect to the wifi
Run the broadband diagnostic first either online or via the MySky app and click the wifi option when it's finished. If everything comes up as OK then have a look at the 2nd link to see if that helps. If possible, an ethernet connected Q box is always preferable though.
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
