20 Sep 2023 09:08 PM
I have a Sky Q router with coax running at 64 mps. We have ordered an upgrade to full fibre and 150 mps. I believe we need an Ethernet cable and an ONT box which will connect to the outside line. I received a short Ethernet cable in the post. But will the engineer bring the ONT box and any other bits? Also how does the full fibre cable in the street connect to the ONT box?
21 Sep 2023 02:21 PM
Posted by a Superuser, not a Sky employee. Find out moreNo I think you are getting confused.
The SR203 is the Sky Broadband Hub NOT the Sky Q hub. If you have the SR203 then this is the correct hub to connect to the Openreach ONT.
The ER115 is the Sky Q hub. If you have this hub then you'll expect a new hub in the post.
Here is a helpful graphical prompt https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
20 Sep 2023 09:13 PM - last edited: 20 Sep 2023 09:14 PM
The ont and outside work to bring the fibre optic up to and inside the house will be done on your activation date
20 Sep 2023 09:22 PM
Additionally the external would be bought into a csp to be spliced with the internal fibre
If you wish you can enter your full postal address below and post the table and notes below after removing your address from the imagd
21 Sep 2023 11:31 AM
We have an openreach engineer here outside the house, just now doing exactly what you said. But I'm still unsure whether the Sky engineer will bring the ONT box with him, as the girl on the phone said we'd get delivery 'of a box' before the engineer turns up. Bit of fun for the openreach guy, he says our duncting goes up the road on our side of the street and the fibre comes down the other side - so he's not sure how to connect the two!
21 Sep 2023 11:42 AM
Posted by a Superuser, not a Sky employee. Find out moreOpenreach will run all cables into your home and terminate it at a white ONT box on your wall. Sky will then send their own hub to connect to that ONT for internet access. So you will essentially have two boxes, one Openreach, one Sky.
21 Sep 2023 11:47 AM
So the Sky box will be sent...?
21 Sep 2023 11:59 AM
Posted by a Superuser, not a Sky employee. Find out moreIt should have been posted to you a few days before activation. When is your activation date?
As far as I know all Ultrafast subscriptions should be sent the SR203 but it sounds like you still have the ER115/Sky Q hub?
21 Sep 2023 02:13 PM
We have the sr203 sky Q already. Ok thanks. We'll expect the other sky box in the port shortly.
21 Sep 2023 03:17 PM
Ok I understand now. That's great. Thanks for your help.
21 Sep 2023 03:19 PM - last edited: 21 Sep 2023 03:33 PM
That's what Sky grandiosely call their 'conversion kit' because it 'converts' an existing Sky Broadband Hub (SR203) in use with FTTC to be suitable for FTTP by going between the WAN ethernet port (#4) on the Hub and the ethernet port on the ONT.
21 Sep 2023 03:23 PM
If there isn't a duct across the road, unfortunately that's going to delay things a bit....
21 Sep 2023 03:32 PM
He found a dunct. Mud in it but he cleared it. And so he's done all the connections and put an ONT on the wall outside.
