Discussion topic: Sky Q minis no internet
Message posted on 06 Jun 2024 02:48 PM
I've been using an Asus DSL AX82U for a number of years with no problem, a couple of months ago my 2 mini boxes started dropping internet, not a massive problem because i rarely use those services on the minis, however i reported this whilst on the phone about something else & an engineer duly arrived yesterday. He thought it must be a problem with the main box & proceeded to change that & the 2 original minis, all brand new equipment & now all 3 say there's no internet connection. tried wireless & wired same result. Everything else in the house Amazon & Apple etc connects fine Sky equipment not having it?
Message posted on 06 Jun 2024 03:32 PM
Re: Sky Q minis no internet
@BorisB was the Q system working when the Sky engineer left? If it was what changes did you make , if it wasn't you need to get the engineer back.
As you use a third party router rather than a Sky hub the set up wil be different the Q minis cannot connect to third party wifi instread they connect to a 5GHz signal produced by the main Q box. This sigbal uses ch36 to 52 so your Asus router should be set to use a different range. The main box will connect tonthe Asus router using the 2.4GHz band giving an internet connection for all Q boxes.
Message posted on 06 Jun 2024 03:47 PM
It was working with a sky router not my Asus which was fine with the previous box, the main box connects to the router fine but insists i have no internet. He advised me to get a "splitter' to run both & just use the sky router for sky products, which im pretty sure is impossible to split an adsl line?
Message posted on 06 Jun 2024 04:31 PM
Do you use the Asus router in AP or router mode?
Message posted on 06 Jun 2024 04:40 PM
i use it as router, couldnt even find my sky router, engineer had to lend me one
Message posted on 06 Jun 2024 04:54 PM
I'd imagine that was referring to using both routers (one behind the other) or possibly having an ethernet switch.
You are correct that splitting the external connection isn't possible.
