Discussion topic: Sky Q hub router - need longer power cable
Message posted on 11 May 2024 12:31 PM
Hi I have a new Sky Q hub router and the power cable that was supplied with it. I need a longer one than 2m supplied, roughly 3m, but everything online is 2m (or looks like it with no lenght info provided and the one I ordered to try, was 2m) or is not compatible. Thank you for an advice.
Message posted on 11 May 2024 01:02 PM
Re: Sky Q hub router - need longer power cable
@Lenyyja Sky do not supply longer cables fot the hubs and given on most hubs the power connection is not standard it is difficult to buy replacement power supplies. Most people use a trailing mains adapter. The exception is the new Wifi Max white hub which can use a USB3 cable to supply power.
