Discussion topic: Sky Q Hub, power light and wifi light on, no internet
This message was authored by: a62
I have been trying all night and this morning to connect to my new sky q hub but it just is not working after reboots.
All cables are correct and the light is green for the power and wifi but the internet light has not lit up at all. I can connect to the wifi on my phone however on my apple settings says no internet connection and nothing loads.
Re: Sky Q Hub, power light and wifi light on, no internet
@a62 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker comes back showing everything good as this is historical data can you click on broadband to run an updated test please.
