Discussion topic: Sky Q Hub SR203 Problem
This message was authored by Podestas This message was authored by: Podestas
I have 2 27"macs  2011 and 2017 + an iPad Pro and iPad mini, on the 2017 and both iPads I an now banned from a site I been going to for 20 years BUT I'm NOT banned from it on the 2011 mac, all are connected to the same Sky Q broadband SR203 hub, I've looked at all the info for both macs on the 192.168.0,1 and as far I can tell they all match other than the DHCP IP last number and some IPv6 addresses,  I'm told that the SR203 HUBs have some internal issues with address trying to asigning the same address twice, do they ?.
 I also found under "Display the routing Table, " Diagnostics; Router Table,  lists all the IPv4 match on both mac, on the IPv6 95% match, should they all be the same ?.
is there an answer to this problem, or is the Hub broken, if so will sky change it ?.
This message was authored by mae-3 This message was authored by: mae-3
Re: Sky Q Hub SR203 Problem
@Podestas
It sounds like the public IP address that is assigned for IPv4 is banned from that site, and the reason 1 device is banned and not the other is that 1 supports IPv4 only and the other IPv4 & IPv6.
To solve the issue try turning off the router for more than half an hour to allocate another public IPv4 address to your connection.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
