Discussion topic: Sky Max Hub not connecting to bulbs
This message was authored by Billy2421 This message was authored by: Billy2421
Hi
1. Just upgraded to Sky Max Hub (white box).
2. Conected well with every thing sky.
3. Great improvement on speeds.
4. However I can NOT get any of my Google items Lights and temperature around the house to work.
5. Before you start i have tried all the normal things and have been able to reconnect them when sky has been updated before.
6. As i have been with Sky for over 25 years this one has got me stumped.
Any help much appreciated.
Billy
Re: Sky Max Hub not connecting to bulbs
@Billy2421
With a white Max Hub you may need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band.
