18
This discussion topic has been answered Discussion topic: Sky Max Hub, Model:SR213 - how to force to 5Ghz only, + MAC ACL not working
Avatar for NaveedZ
Level 2 icon
This message was authored by: NaveedZ
Re: Sky Max Hub, Model:SR213 - how to force to 5Ghz only, + MAC ACL not working
The web interface for the SR213 is not supported by Sky.
I was able to play around the web interface on the SR203 from 2022, and now the web interface is not support on SR213 from 2024.
If that's the stance from Sky then it's a regression.
I had to download the app to manage it, and as you mentioned it's limited functionalities.
Thanks for your update
@NaveedZ it is what it is I am afraid the SR213 is even more locked down than the earlier hubs. I have explained why there is movement away from managing routers with a  web interface moving to an app which is something many router manufacturers are doing.
You can take your issue up with Sky but from,personal experience I doubt you will get anything from doing so.
This message was authored by: CuddlyJake
I am haviung the same issue, I would like to split the SSID so that I can force a connection to gGhz instead of the slower 2.4, come on Sky, **bleep** am I paying for?
@CuddlyJake like many other WiFi6 routers you cannot split the WiFi bands on the white Sky Max hybrid. Instead the procedure is to disable the 5GHz band temporarily, connect the  devices giving issues and re-enable the 5GHz band again. Works for most people by reports.
You can replace the hub with a third party router if you wish or buy a cheap,wifi access point and connect the devices to that
Answered - Go to Answer
