Discussion topic: Sky Hub Serial Numbers - Date of Manufacture?
Message posted on 30 May 2025 03:13 PM
Hi All
Having received my new replacement Sky Hub SR203 yesterday (many thanks Sky Tech Support), I noticed that the new replacement hub has an additional settings page, which my original SR203 doesn’t have:
- Advanced, Remote Management
This is curious as there must have been internal manufacturing specification changes to the SR203’s over time, which the software updates don’t always include on their own.
Is there any way to decode a Sky Hub’s serial number in order to ascertain its date of manufacture?
Also does anyone know if there is a in depth user manual for the SR203 around anywhere – especially covering the ‘Advanced’ settings?
KR
Message posted on 30 May 2025 03:19 PM
Re: Sky Hub Serial Numbers - Date of Manufacture?
@THX1138 For sure there is no user manual of any type. Not sure about the seial number to manufacture date, packaging box has 2022 on it if off any use!
Message posted on 30 May 2025 03:31 PM
Interested to see if you still have ddns option. My hub has ddns ( now deemed insecure) but no additional remotemanagement that i can see. It would suggest that it is a featute that can't be delivered by firmware upgrade
Message posted on 30 May 2025 03:34 PM - last edited: 30 May 2025 03:41 PM
@cookiemonsteruk @THX1138 Can power up mine if anyone needs and take a look see!
On it now,!!!
Message posted on 30 May 2025 03:39 PM
Aye , lets compare firmware 😁
System Details
helpSky Stream , Sky Superfast, SR203 router, Tp link td w9970 + Asus RT AX58U (backup), Xbox Series X, google home mini, LG 55 inch uhd tv, with Dolbyvision, samsung a5 2017 and samsung s21
Message posted on 30 May 2025 03:43 PM - last edited: 30 May 2025 04:17 PM
I think that means it's running an older firmware release which will be updated automatically and the option will disappear. Remote access in the way it used to be implemented isn't compliant with the recent regulation on secure internet devices (under the Product Security and Telecommunications Infrastructure Act 2022)
Message posted on 30 May 2025 03:59 PM
@cookiemonsteruk @TimmyBGood @THX1138 Was think along the same lines as older FW and removed page with the more upto date version anyway couple pages below screen captured as got it out the box.
Message posted on 30 May 2025 04:22 PM
The firmware in place when it arrived should give you a clue. Launch of the SR203 was September 2019. Earliest reported firmware I can find is 3.04.1462.R, from November of that year. That appears to be the earliest mention of the DDNS situation.
Message posted on 30 May 2025 04:29 PM
@Deb3000 Wonder how many changes there has been since that time? Have noted and Mar 2025 fw on the box was 7.02.0501.R when received and setting it up offline.
Message posted on 30 May 2025 04:36 PM
Message posted on 30 May 2025 05:22 PM
When I first connected the new replacement hub it was on an earlier firmware version, but it subsequently did an update after being switched on for a while to 7.04.0004.R, which I believe is just behind the most current version 7.04.0100.R.
@TimmyBGood Let’s see what happens when the 7.04.0100.R update is installed and see if the ‘Remote Management’ page disappears.
@cookiemonsteruk The new hub I was sent shows the same DSL Firmware Version as yours - A2pvfbH043p1.d26u.
KR
Message posted on 30 May 2025 05:28 PM
@THX1138 What's the specific reason for the hub swapout issue wise!
Message posted on 31 May 2025 02:58 PM
@TimmyBGood As if by magic, hub updated overnight to 7.04.0100.R and the ‘Remote Management’ page has vanished.
@JimM1 The old SR203 – it was an early unit, was experiencing some weird Wi-Fi issues, like randomly losing the SSID names and settings and slow 5GHz 80MHz ch36 performance when only being 1 meter away. The Sky Tech Support person did a remote check of the hub and said he would send out a new one – not sure what he discovered.
Probably a dumb question, but is there any preferred ethernet port (1,2,3,4) to use for the ONT ethernet cable to plug into? I also upgraded this cable to Cat6.
KR
Message posted on 31 May 2025 03:01 PM
@THX1138 If you are FF then it can only go into port 4 on the lan, furthest right as you look at the back off the hub. See the picture above?
Message posted on 31 May 2025 08:02 PM
@JimM1 Yeap, that's the port I've used and connected the ONT to - Port 4 (WAN). Thanks for the confirmation.
