This discussion topic has been answered Discussion topic: Sky Hub 2.4 GHz Dropping All IoT Devices
Message posted on 19 Nov 2025 12:02 PM
Re: Sky Hub 2.4 GHz Dropping All IoT Devices
I reset hub to default, login try changing just just lan tcp from 192.168.0.1 to 192.168.1.1 Starting IP Address 192.168.1.2 Ending IP Address:192.168.1.254 click apply,
message:
Change in LAN IP setup will restart the Sky Hub and terminate any active connections to the Internet click ok. nothing happens if i mannauly reboot hub no changes 🤔
Message posted on 19 Nov 2025 12:19 PM
@WelshY1987 If you fixed all the IP's in the Lan Manager then that scope change to the IP the DHCP may just not like it being done that way! Not sure what you have set?
Message posted on 19 Nov 2025 12:27 PM
@JimM1I just ran a scan through my Sky account, and it indicates there is an issue with my Hub. Hopefully, this is the cause. I’ve placed an order [for the replacement/upgraded Hub] and will wait to see if that resolves the problem. Thanks for your time and help. ❤️
