The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
24 Mar 2022 02:17 PM
Trying to connect to Sky broadband. Have entered the new Sky name ad password but is not accepting it. Says to press WPS button for several minutes and try again. Sky Hub does not have a WPS button! Totally confused!.
24 Mar 2022 03:21 PM
Posted by a Superuser, not a Sky employee. Find out moreThis discussion has been locked
24 Mar 2022 02:21 PM
Posted by a Superuser, not a Sky employee. Find out moreAll Sky Hubs have a WPS button. If you have the flat Sky Q hub its on the front, the two small black arrows. If you have the newer upright Sky Broadband Hub it is on the side of the hub, again two small black arrows.
Posted by a Superuser, not a Sky employee. Find out more24 Mar 2022 03:29 PM
Thank you for your help.
24 Mar 2022 03:32 PM
Hi James,
Thank you so much. It has worked!
24 Mar 2022 04:40 PM - last edited: 24 Mar 2022 05:51 PM
Having the WPS button as black-on-black way down on the side there was always a really silly design choice: you're far from the first person not to have spotted it.
As I've remarked elsewhere, BT make their equivalent much more prominent, but then locate it on a rounded edge towards the back of the Smart Hub where it's really easy for a fingertip to hit the power button instead...
