Discussion topic: Sky Fibre Passsword Change
Message posted on 24 Jul 2025 12:49 PM
Quick question. I currently have Sky Broadband (partially fibre) and am changing to Sky Full Fibre. I have a round 30 gadgets linked on my broadband from door bells, firesticks, smart plugs plus tablets and phones.
Rather than change every gadget individually, can I just change the name and password in the new router to the same as the old one and everything will just happily connect. Cheers
Message posted on 24 Jul 2025 12:58 PM
Re: Sky Fibre Passsword Change
Yes, if you set the new router’s Wi-Fi name (SSID) and password exactly the same as your old router, most of your devices should reconnect automatically without needing to update them individually.
