This discussion topic has been answered Discussion topic: Sky Fibre Broadband (FTTP) with Ubiquity USG (i.e. 3rd party router)
Message posted on 27 Jun 2023 04:26 PM
Re: Sky router replacement (other brand)
Thanks @jamesn123 , just had a thought, will the 2.4ghz wireless be good enough for a skyglass connection or is that likely to suffer?
Message posted on 27 Jun 2023 04:28 PM
Again depends on the WiFi environment around your house. If its quite populated with a lot of other routers & devices it could suffer, especially during evenings & nights at peak usage time.
If its a fairly quiet area you should be okay.
Message posted on 27 Jun 2023 04:45 PM - last edited: 27 Jun 2023 05:02 PM
My personal opinion would be
- If you are in FTTP build plans then just get the TP-Link TD-W9970 on its own until you get another Sky hub or get the TD-W9970 with a router only Asus model as you'll find the WiFi a lot better than even your Sky hub and then you'll be able to use it when Full Fibre arrives.
- If you are not in FTTP build plans you'll want to make the most of the line speed that you can get from FTTC so I'd recommend getting an Asus Modem/Router combo and using that instead of your Sky hub because again it'll perform better and offer more features.
Message posted on 28 Jun 2023 10:04 PM
Just to round this thread out, I got the TP link router as discussed, arrived this morning, installed using info supplied by Cookie Monster and worked instantly.
Brilliant, thanks for the help @jamesn123 and @cookiemonsteruk you should both work for Sky!
Message posted on 29 Jun 2023 10:10 AM
Yeah if only I got paid to do this 😂 What do you reckon we are worth @cookiemonsteruk ?
Message posted on 29 Jun 2023 10:15 AM
Couldn't agree more 😁
Also @mae-3 once said i should be on commission from asus. We would be worth some money 😁 So i guess we just accept the compliments and praise with gratitude and a slightly inflated ego 😁
Message posted on 19 Dec 2023 02:39 PM
Re: Sky Fibre Broadband (FTTP) with Ubiquity USG (i.e. 3rd party router)
Hi all,
apologies to jump in this after 18 months, I have had FTTP installed today and Sky haven't sent me a router.
I have the USG and have tried several attemps at programming the information on this thread no no avail.
Any advice is welcome
Message posted on 19 Dec 2023 04:44 PM
Hi @Maffy-88
To get going straight away SSH the the USG and enter the following
configure
delete interfaces ethernet eth0 address dhcp
commit
set interfaces ethernet eth0 dhcp-options client-option "send dhcp-client-identifier "bacons";"
set interfaces ethernet eth0 address dhcp
commit
save
To preserve this whenever the USG re-provisions you'll need to add the folloing into a file call config.gatewway.json on your controller.
I have a cloud key gen 2 and it's in /usr/lib/unifi/data/sites/default/config.gateway.json
"interfaces": {
"ethernet": {
"eth0": {
"address": [
"dhcp"
"dhcp-options": {
"client-option": [
"retry 60;",
"default-route": "update",
"default-route-distance": "1",
"name-server": "no-update"
If you don't have the directory structure you can go to legacy mode and add a floorplan. Save then switch back and the directory structure should be there.
You may need to chown/chmod the file
Message posted on 19 Dec 2023 04:47 PM
Here's some more info on the config.gateway.json file
Message posted on 19 Dec 2023 04:56 PM
Thanks @Doofusburger ! I have been trying for hours. does this look about right?
admin@USG# set interfaces ethernet eth0 dhcp-options client-option "send dhcp-client-identifier "bacons";"
[edit]
admin@USG# commit
save
[edit]
admin@USG# save
Saving configuration to '/config/config.boot'...
Done
[edit]
admin@USG# admin@USG# set interfaces ethernet eth0 dhcp-options client-option "send dhcp-client-identifier "bacons";"
vbash: admin@USG#: command not found
[edit]
admin@USG# [edit]
vbash: [edit]: command not found
[edit]
admin@USG# admin@USG# commit
[edit]
admin@USG# save
Done
[edit]
admin@USG# [edit]
[edit]
admin@USG# admin@USG# save
Message posted on 19 Dec 2023 05:02 PM
If you were in configure mode it should be ok.
It should
Don't forget to update the config.gateway.json on your controller though as this config will be over-written if the USG is re-provisioned or rebooted.
I don't have any manual settings on the Primary WAN1 Interface apart from my expected speeds
Message posted on 19 Dec 2023 05:06 PM
Thanks.
Still don't seem to have a connection. Don't want to save the JSON file if it's wrong.
Message posted on 19 Dec 2023 06:23 PM
Got it!
Had to pinch a bit of the coding from @Mr+Slant and we are good!
Thanks for your help, I will look at trying to do the JSON file saving when I'm abck tomorrow.
Message posted on 24 Aug 2024 10:49 AM
I know this is an old thread, can I please confirm my understanding.
I have two options:
without SkyTalk
Openreach ONT > USG or UDM
with SkyTalk
Openreach ONT > SkyHub > USG or UDM
is this correct? Do I need a UDM in either option or could I continue to use the USG?
Message posted on 02 Sep 2024 03:35 PM
Yes that is correct. Note Sky hub doesnt have modem mode so the USG/UDM would have to act as an IP client router or AP, it cant authenticate directly to the line.
