Discussion topic: Sky Fiber (cityfibre) using Unifi UDM SE as router
Message posted on 04 Sep 2025 01:05 PM
Hi we are having sky fibre installed and alessdy have in place a unifi dream machine se which is my primary router.
I would like to setup my own router directly from the ONT.
Is it PPPoE or DHCP with option 61?
Does anyone know what the configuration should be? Waiting for the engineers to finish the fibre install but want to avoid using the sky router as everything alessdy configured using my unifi gear including my own access points etc.
Message posted on 04 Sep 2025 01:20 PM
Re: Sky Fiber (cityfibre) using Unifi UDM SE as router
@balsanghera DHCP and option 61 if your router supports it, but may well not be needed, do setup your sky Hub, it's the only item that sky will help you with, nothing else!
Message posted on 04 Sep 2025 01:27 PM
I can set up option 61 through the legacy gui for ipv4 assuming this is correct and I don't need ipv6?
Message posted on 04 Sep 2025 01:29 PM
@balsanghera That would be correct!
Message posted on 04 Sep 2025 03:04 PM
Nice and easy. Speed test maxing out over my existing WiFi access points. The only thing I have noticed I can't run speed test on my UDM SE and the for some reason the Nokia ONT data light is now orange instead of green.
