2
This discussion topic has been answered Discussion topic: Sky Engineer with aftermarket router
This message was authored by: Kramb0
So my parents internet keeps disconnecting, though wifi connection to router is fine
They have an engineer coming out tomorrow.
Problem is they have an aftermarket router setup so we could have  much stronger signal.
Will this be an issue when they come round?
Will they just say it's because of this other router?
Re: Sky Engineer with aftermarket router
@Kramb0 Sky permit but do not support third party routers. It is unlikely the engineer will care too much but it would be wise to have the Sky hub available so if they do it can be swapped in.
What is surprising is Sky have booked an engineer at all as normally they refuse to do that unless their diagnostics which require the hub to be connected indicates a fault.
Avatar for Kramb0
Level 2 icon
Thanks for the response.
Will see what happens and yes we still have the Sky router.
Cheers
