Discussion topic: Sky Broadband slow
LauraB1992
This message was authored by LauraB1992 This message was authored by: LauraB1992
Re: Sky Broadband slow
@cookiemonsteruk
ok thanks ill have to sort that out and also look into a new router.
Ive just checked my networks i can't seem to find my 5ghz band, is there something im missing ?
@LauraB1992
In the link after unticking synchronise 2.4ghz and 5ghz go to 5ghz and add something like -5ghz at the end of the 5ghz ssid . The two bands are along the top of the wifi section
This message was authored by lightbulb73 This message was authored by: lightbulb73
I find sky has the slowest speed 51mb is the fastest they do where i live  yet you find most other providers have speeds up and over 500mb speeds in my area so do some research before going with sky if your a pc gamer then sky is prob not for you.
That would suggest other ISPs are reselling FTTP while Sky only has FTTC available at present.
This message was authored by Anonymous This message was authored by: Anonymous
That is entirely area dependant and is poor general advice.
