Discussion topic: Sky Broadband connection dropping frequently
This message was authored by: Bhavyen
Have been experiencing SKY broadband connections dropping over the entire day in Peterborough area(PE1) .
 This needs to be resolved as this affects the WFH and other routine activities . The Sky service checker from the app also falsely mentions no service issue found whereas the fact is that there is a genuine dropping of internet connection over the entire day.
Re: Sky Broadband connection dropping frequently
@Bhavyen
If you haven’t done it already use the below link to check to see if there are any problems/outages nearby https://www.sky.com/servicechecker
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
▪️I AM NOT A SKY EMPLOYEE ▪️
