Discussion topic: Sky Broadband and WiFi not working
This message was authored by: Katie6g
Was watching YouTube and it went into loading mode and black screen, was able to get it WiFi back on, it turned itself back off. I turned tv off and hit home button it came back on and turned itself back off. I have reset the WPS button twice on router and tried turning tv off 3 more times, I need Internet to work as my daughter works from home and starts at 9am.
Re: Sky Broadband and WiFi not working
Hi @Katie6g
Your post is quite confusing as you seem to switch between talking about a TV & the router. Is your broadband not working on any device? If not, can you please tell us what lights are lit on the hub?
I am NOT a Sky Employee
Avatar for Katie6g
Broadband now working, seems sky Q box and router don't seem to be communicating, tv cannot access on demand, home, catch up tv, sky cinema, sky store, sport, kids, audio and music and Apps from the side menu. But I can access the channels from the TV guide. Though I still can not access Netflix, YouTube or any apps, and the reset option does not appear under network settings as, I am already connected. Is this more straightforward @jamesn123
@Katie6g
Yes makes more sense thanks.
Its odd that your Sky Q box is showing connected but wont load anything. If you go into setup/advanced you should be able to reset the connection anyway so have you tried that?
Best option if possible is to connect the Sky box to the router directly via an ethernet cable.
Avatar for Katie6g
Unfortunately no Hdmi cable or Ethernet cable available though this sounds a good idea!
Avatar for Katie6g
@jamesn123 went into advanced menu as suggested and selected the 1st option, as it was the least damaging to any recordings etc, and only affected box and remote, reset back to factory settings, if anyone else tries this don't freak out, your remote will not work when it asks you to push the home button, but to reprogram your sky q remote press 7 and 9 together wait for 4 red flashes on remote, then press 1 and 3 and wait for another 4, now you can push the home button to turn your TV on. Unfortunately this advanced reset did not work, all it managed to do was loose me, my connection to sky go and sky multiroom and will not let me reactivate. I'm a Diamond customer and am now wanting to throw my box in the bin lol
@Katie6g
I would get on the phone to Sky at this point or we can escalate your post on the forum
Avatar for Katie6g
@jamesn123 reset router about 4 times, in the end it connected to sky q box, got sky go and multiroom set back up, and then sky apps would not appear, waited to see maybe if it would take time, have went back into advanced menu to refresh apps, and see if it works. Brilliant apps up and working, I think my Sky Q box on it way out! Thanks for the help
