Discussion topic: Sky Broadband - Fire
Re: Sky Broadband - Fire
@nousername71 wrote:
my neighbours have 100% not had to pay for it due to the fault.
They aren't billed separately for the service: it's priced into the business model.  Sky chooses not to offer the same facility.
Avatar for nousername71
This message was authored by: nousername71
Thanks for all the help, that's been really useful.
Wish I had posted on here in the first place, rather than the super painful conversations with Sky support.
@Chrisee wrote:
@nousername71 not sure you can switch to EE while the Openreach line is out of commission the transfer will simply stall. As I posted earliier if you are still in the 24 month contract period Sky will charge cancellation fees unles they wave the contract.
You should be accumulating £9.98 for every working day after the first 2 in compensation which will be credited once the fault is cleared. If you cancel the contract you will lose that money. Buying a cheap mobile router with a pay as you go sim maybe a better solution .
"You should be accumulating £9.98 for every working day after the first 2 in compensation which will be credited once the fault is cleared"
Can you please tell me where it's stipulated, that I should get £9.98 for each working day?
thanks
@nousername71
Actually each day including weekends after the first two working days (because that's the Openreach target time to fix)
https://www.sky.com/help/articles/auto-compensation
https://www.ofcom.org.uk/phones-and-broadband/service-quality/automatic-compensation-need-know
