Discussion topic: Sky Broadband Down Co. Kildare, Ireland
This message was authored by: LiamM86
Any idea what's going on with the broadband in Co. Kildare? It's been down for past hour and no updates provided.
Re: Sky Broadband Down Co. Kildare, Ireland
@LiamM86
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
If you’re still having problems you may need to call Sky Ireland to report it. Dial 150 free from your Sky Talk landline (if it’s still working).
* The above relates to UK customers. Not sure if it's exactly the same in ROI*
Avatar for LiamM86
Considering my whole estate is without internet, I didn't need to do these steps
@LiamM86
Considering you didnt state that in your original message how were other users supposed to know your whole estate was down? The forum is mostly customer to customer based, you aren't speaking directly with Sky here.
I am NOT a Sky Employee
