Discussion topic: Sky 150mb g.fast
This message was authored by: atherlon
Sky 150mb g.fast
I've just had G.fast installed and I have a sr-203 router but I've read that the sr204 is for G.fast . Can I replace mine with sr204 ??
Re: Sky 150mb g.fast
@atherlon
G.fast will only work with an sr204.
Has your connection been activated yet?
@atherlon
As @cookiemonsteruk indicates, it's the 204 which has a G.fast modem: the 203 is specified for FTTC and FTTP.
Avatar for atherlon
Level 2 icon
Yes went live yesterday 500mb fibre
This message was authored by: mormegil
Gfast via sky is only offered at 150mbps ultrasfast product if you have the 500mbps ultrafadt plus then it will be fttp which is why no replacement router was sent
