Discussion topic: Size of sky hub
This message was authored by: Tracey144
Size of sky hub
Hello
We are hopefully moving soon and will possibly be going with Sky
Can anyone tell me if the sky hub for fibre will for fit through a normal letterbox ? Or is it a bigger parcel
Just we will not be at the property for a while and want to make use of the deal
Re: Size of sky hub
@Tracey144
The hubs will not fit through a letterbox, nor would I expect a postman to let a Sky appliance drop onto the floor. Royal Mail deliver it and if no one's in tend to put a card through the letterbox and send a message as to where they've left it (behind a wheelie bin is a favourite).
Avatar for Tracey144
Re: Size of sky hub
Perfect
Appreciate your reply
I will order it and try and get it redelivered when I am therw6
Appreciate your answer
Re: Size of sky hub
Also do u know how long they take to post out please? Thanks
Re: Size of sky hub
@Tracey144 hubs are dispatched to arriveca couple of days before activation. Most postmen leaveca card with thecaddtess of the local mail delivery officecwhere you can pick up the parcel ratger than lezving it at the property.
Re: Size of sky hub
We are possibly moving to 5 hours away by train and won't be able to go back there too often. Until we move properly
I will see what happens
