Discussion topic: Since moving to sky fibre I can’t connect to British Gas Hive
This message was authored by CCZ This message was authored by: CCZ
Since moving to sky fibre I can’t connect to British Gas Hive.
They're asking is anything at the Sky end stopping the hub from coming online - and are the following router ports open, as these are what the hub uses:
-UDP port 123 (NTP)
-TCP port 443 (HTTPS)
-TCP port 5671 (AMQPS)
any ideas?
Re: Since moving to sky fibre I can’t connect to British Gas Hive
@CCZ
Could you go to your my sky app or sky.com account -> product settings -> broadband shield and disable it . Not ideal but hive advise that
CCZ
Already done but doesn't seem to be making any difference 😢
@CCZ
Short of been stuck with using the control buttons i'll tag another superuser
@jamesn123 i have vague recollections that you have or had the hive system ? Any ideas?
@CCZ
In the meantime which hive hub do you have? Take a look below either you don't need firewalls or may be ones missing
https://helpforum.sky.com/t5/Broadband/Help-trying-to-connect-Hive-Hub-to-Sky-Router-need-to-open-po...
@CCZ
Apologies i missed the top udp rule 🤔
@cookiemonsteruk
Good memory, yes I do have hive!
@CCZ
There are no special ports that need opening for hive to work on Sky broadband. Just make sure Sky Broadband Shield is disabled & that you are connecting the hive hub directly to the sky hubs ethernet port as often it wont work through a switch.
If you are still having trouble you likely need a replacement hub as I know previously many people who have had issues with Hive & posted on this forum ended up having faulty hubs
I am NOT a Sky Employee
