4
This discussion topic has been answered Discussion topic: Since moving from Vodafone to SKY, secure folder says results hidden by safesearch.
This message was authored by: Martyn21
Since moving from Vodafone to SKY, secure folder says... results hidden by safesearch.  Safesearch says... administrator controls settings.   Please help.
Re: Since moving from Vodafone to SKY, secure folder says results hidden by safesearch.
@Martyn21 by default new Sky broadband accounts are set to age 13 in the Broadband `shield account holder can change the setting in the My Sky app. Under product settings.
Are you a Sky Broadband customer as safe search I believe is related to the Sky Broadband Shield settings.
Avatar for Martyn21
Hi, yes I am.  What should I do now?  Thanks for helping.
Avatar for Martyn21
Hi Chrisee.   All sorted.   Thank you so much.    x
