Discussion topic: Signal strength from router is not adequate
This message was authored by: Eightrax
Message posted on 01 Feb 2025 08:02 AM
Router is connected on the far side of my flat, and all my devices are about 15m away in my lounge and the signal strength is rubbish.
Find out more
Message posted on 01 Feb 2025 08:08 AM
Re: Signal strength from router is not adequate
@Eightrax flats can be difficult to network as internal walls are usually solid and there is lots of close neighbours so lots of interference. The answer is normally to get an extender which Sky will supply if you buy the WiFi Max bundle see https://www.sky.com/help/articles/sky-wifi-max or you can buy a two unit third party home wifi system turn off the WiFi on the hub and use thst instead.
