Discussion topic: Shy Broadband Hub
This message was authored by Yorkiecherry This message was authored by: Yorkiecherry
Shy Broadband Hub
Hi
I have a Sky Q Hub but I have been told I should have Sky Broadband Hub. How do I get one?
Re: Shy Broadband Hub
@YorkiecherryWhy have you been told that you should have the Sky broadband hub and not the Sky Q router?
Yorkiecherry
I no longer have Sky Q. I use Sky Stream
@Yorkiecherry
That makes no difference to the Hub model: typically Sky supplies the Broadband Hub to customers paying for the Broadband Boost supplement.  What's confusing is that the letter Sky sends out when Q television is cancelled implies that a Q Hub is returnable too, which isn't the case if Sky Broadband is being retained.
